- 26 Feb 2010
- Surrey, UK
The 14 day return policy "satisfaction guarantee" seen here:
http://www.overclockers.co.uk/support.php
Does this only apply to products that have been un-opened, or are you able to send back a product after opening / testing it and still recieve a full refund?
The only reason I ask is because I am not 100% happy with my current set of speakers that I have had for a while. They are a 5.1 surround sound set by Logitech (the Z506 set) and I also have a Creative Titanium sound card. Everything is working fine mechanically, but the satellite speakers are basically just very bad, the sound quality is quite "tinny" and they crackle a bit on certain high pitched sounds. Then the bass is like SUPER MEGA LOUD cos the subwoofer is massive and basically annoys the neighbours to no end if they are in. The mid-range is pracitcally non-existant. It's either tinny or SUPER MEGA BASS xD
I wanted to maybe try out a 2.0 sound system, such as the Creative Gigaworks 2.0 speakers, but I'm not sure if the sound quality is going to be better or not, I've never owned a set of speakers without a seperate sub-woofer myself.
So basically wondering if it would be possible to order some speakers, unpack them and test them out, then post them back if they are not any better than my current setup and get a refund (obv. I will pay postage costs).
If they are better, then I will keep them and sell off the old ones.
Anyone know if that is allowed? Is it a common thing to do?
:S
:S
