- 2 Mar 2009
I currently have a 180GB HD which is running out of room. I want to buy a 500GB HD but i was wondering if i should have the 500GB one as the secondary one? or the other way round. Also if i want to move games with all my saves over to the 500GB HD do i just move the directory's in program files? thanks
drive you can then restore to your new 500gb as your primary active. If I was you, I'd buy a cheap IDE drive to hold your images for future restore and image your 500gb. OR just rebuild your 500gb from scratch and keep your 180Gb as a standby if your 500gb ever fails and you loose the lot.
