- 18 Oct 2002
- Cheshire
So, theres this plane on a treadmill......
WS_TailGunner said:technically, yes- but a fly is already exerting force on the air in order to stay hovering- the air in the car doesnt move when you pull off, so neither does the fly...same as you sitting on the seat essentially.
In or out of the car?hendrix said:Ok, how about if you throw a ball in the air (Neglecting air resistance)![]()
Missing my original point here. If you throw it (sitting on top of the car) straight up, fair enough wind resistance will slow its horizontal velocity down slightly, but it's not going to 'Go Bye Byes' as suggested above.Phnom_Penh said:In or out of the car?
That's not quite true, when you accelerate the air is compressed towards the back of the car, until acceleration ceases and the air is then re-distributed although the effect isn't really noticeable.WS_TailGunner said:technically, yes- but a fly is already exerting force on the air in order to stay hovering- the air in the car doesnt move when you pull off, so neither does the fly...same as you sitting on the seat essentially.
But the principle is supposedly sound
Scuzi said:You are making the assumption that the fly has accelerated from a standstill to the speed of the car. Relative to 'space' the fly is travelling at 80mph inside the car and as there is no resistance, the momentum keeps it going. However, if the car accelerated from a standstill with the fly hovering inside, unless the fly accelerates at the same rate as the car, it will splat on the rear.
chopchop said:the question was a fly in a car travelling at a constant 80mph, to which i answered correctly.
If the fly magically appears out of no-where, then yes it has to fly at the same velocity as the car.PaulStat said:Ok so a fly is in flight in a car that is travelling at 80mph, since the fly isn't actually touching the car as such. Does it have to fly 80mph in the same direction to avoid being splatted against the back window?![]()
It will slow down, as I said before the extent of which depends on height.hendrix said:Missing my original point here. If you throw it (sitting on top of the car) straight up, fair enough wind resistance will slow its horizontal velocity down slightly, but it's not going to 'Go Bye Byes' as suggested above.
Burned_Alive said:So, theres this plane on a treadmill......
Scuzi said:a fly is exactly the same thing, only it doesn't have a string holding it on.
hendrix said:Lets say you are standing on top of a car thats travelling at 30mph. You jump vertically. Do you 'fly' backwards???
No!
Scuzi said:I didn't say you were wrong.
Err, wrong.Phnom_Penh said:It will slow down, as I said before the extent of which depends on height.
What if the fly turned on the torch it was holding as well?gord said:Actually
If your travelling at the speed of light on a treadmill and the plane contains a fly, do you have 1 sandwich or 2?
Can. Worms. Explode.
WS_TailGunner said:ah- there IS a string of sorts- the fly is exerting a force on the air in order to "hover"
chopchop said:but you posed a completely different question to the one i answered.
And its blatently obvious to anyone with an understanding of newtons laws of motion that "An object will remain stationery or continue moving at constant velocity, unless acted on by an external force"chopchop said:?? what has that got to do with my answer???
i know what would happen to a person that was stood on a car. it is infact blatently obvious to anyone. think motorbike rider.
