Question about dual channel ram.
Caporegime
12 Mar 2004
England
I was wondering what having dual channel ram actually does to things like memory speed and such. Since people are always saying run ram in dual channel mode.
Do you mean memory speed as in the DDR frequency it runs at or the latencies?
Whan running in dual channel its possible that you will have to use a slightly lower freq. but this loss is more than made up for by the benifits of dual channel
Dual channel itself is where the memory and cpu/nb can communicate with each other at the same time rather than cpu -> mem then mem -> cpu.
I think it enables info to be sent on the rise and fall of each clock cycle
Running dual channel means that the two memory modules are being accessed by seperate memory controller channels, theoretically doubling memory bandwidth, it doesn't affect timings or latencies. The best image I can think of is its like turning a single lane road into a dual carriage way, the cars all travel at the same speed, but now you have two lanes, twice as many cars can get from A to B.
In real world terms you see about a 2-3% increase in gaming performance on Socket A and a 10% ish performance increase on A64 when using dual channel over single channel.
Energize said:
So would 2 400mhz sticks be equal to 1 800mhz stick then?
Theoretically yes, you could have a single 512mb module in single channel and 2x256mb modules in dual channel. The latter solution should give twice the bandwidth, and this can be seen using synthetic tests such as SiSoft. On socket A it is far less noticeable, but A64 shows the bandwidth increase in SiSoft very noticably.
For real word apps the increase in bandwidth has a small to moderate effect on performance.
But cpus cant utilize all that can they? I thought amd 64 cpus only had a 1000mhz htt. Unless you can overclock the fsb by 60%?
Why did everything switch to ddr 2 surely they could have made faster ddr ram? They already had 625Mhz ddr ram didnt they and now you need new ram when you want to upgrade. :(
massively. corsair xms2-8500 for example is varified to run at 1066mhz. dd2 has the potential to be much faster, but atm its at the expense of timings.
DDR2 had already started to mature on graphics card (is GDDR2 the same as DDR2 anyone? I'm not actually sure) and it was probably far more economical to switch to DDR2 than keep pushing DDR1.
So because the memory timings are slower are the am2 systems at stock are slower than the equivilent 939 systems?
Nope because while the timings are slacker the frequency is higher. AM2 rigs are slightly faster than 939 rigs, not by much though.
Yeah a 1-2% boost at most really. S939 was never limited by bandwidth, so adding more with DDR2 is going to minor gains with current gen processors.
Oh and another question does more ram = possibly more latency because the pc has to search a larger amount of ram to find the data needed?
