I got today the swiftech kid and am a bit confused as to how to prepare the liquid. It says in the instructions:Simply empty the concentrated coolant into a 1liter plastic bottle, and complete filling with distilled water. Your coolant is now ready. It goes on to say how much % i should use as a additive. My question is How do i know if what am planning to use its 5% or 10%? With the eye i can't tell much
i thought its 5% of the bottle into a 1liter of distilled water.
and yes its a good choice. I am also a first time watercooling noob lol. Now I havn't chosen a kit gone custom but I still assume you have to cut up all the tubing? So the best thing to do and what I am doing is to fit the CPU and GPU (if you have a GPU that is) and then get all the tubing and positioning of the reservoir sorted etc. Then just take the blocks of and put a towel on the center divider of ** case and put the blocks on that. Remove everything from your case apart from the watercooling stuff and then hotwire a PSU. Then just fill ** loop and test for 24hrs that way nothing is going to get damaged if there is a leak. Then when you know the loop is leak free just install everything into the case that way you don't have to empty the loop either just screw the blocks to ** mobo and graphics card.
