Question about OC'ing 3900x, coming from intel.
22 Aug 2010
In My Command Center
I have only ever had intel systems but recently I decided to move to AMD. As I have never used or been interested in AMD eco systems this is a little alien to me, however I did research how to OC the 3900x, I've changed a lot of the "auto" voltages to what has been recommended and I have managed OC'd my 3900x to 4.4ghz all core @ 1.33v.
I have a full custom loop with two 360mm rads so the CPU never goes above 77c under synthetic loads, it idles at 40c and when gaming it doesn't see above 55c(ish).
My question is, is it safe to run AMD CPUs at fixed frequencies and voltages?
If not, how do I get it to clock down and drop voltages?
I can't see how to do it?
My specs are -
3900x
Asus maximus hero x570
Latest bios
Many thanks
**Edit** I have bios OC'd, I don't know how to use RMS.
I think ppl generally stick on PBO and be done with it.
Manual OC will lock the CPU and vcore to those values therefore you may get shorter life span out of the CPU. unless you got p state overclocking facility like the ones in ASUS mobo, which you own. By that you can determine what vcore to run each pstate at for the desired frequency to save energy and eek out cpu life.
