Lol did you forget your first post after the 8mins?Only someone like donald trump would want an oven cooked steak. And then he'd probably put tomato ketchup on it. The Heathen.
As said above it’s a similar principle to sous vide. Much easier to get an exact temperature (if you do it correctly) and it’s called a reverse sear because you sear it afterwards and get all the good crust/browning which is the benefit to frying/grilling in the first place.A little bit of science goes a long way in cooking. Try salting your steak 1hr before cooking (no less than 45mins) and I guarantee you’ll be converted. That’s just one example. The science of reverse sear or sous vide isn’t actually that complicated. You want your steak a particular done-ness which means a certain temperature. Why not cook it tk exactly that temperatureGet in the bin.
Steaks at room temp. Salt and pepper both sides. Vegetable/sunflower oil in cast iron pan until almost smoking, 2 minutes a side (depending on thickness). Rest. Done.
OXO cubes? Butter? Ovens? Get in the bin.
don’t need much really…
Not sure if @Ormy1 is joking or not. Leaving meat at 30c for 4-6hrs sounds like a nice way to grow some bacteria on it to me![]()
Why only pepper? As I mentioned above salting steaks (at least 45mins before, preferably longer) has given the biggest improvement to them of anything I’ve tried.Season with pepper
I only reverse mine. Couldn't have it any other way now. Cooked a couple when camping on a gas grill a few weeks back and they were poor in comparison but needs must.
Take out of fridge and allow to get up towards room temp, few hours.
Season with pepper
In the Traeger at 102c. Target cooking temp 46 - 48c for smaller steaks and a full eye fillet. 50 - 52c for a super thick Tomahawk (or its too rare at the bone). Slice of eye fillet takes about 25 minutes, full one an hour and a bit. 800g Tomahawk around 45 mins.
Heat a fry pan on the gas hob with a splash of grapeseed oil until it smokes.
Chuck the steaks on, 30 sec or so each side, turn twice.
Put on a warm, not hot, plate and add a lump of butter to each one.
Cover with foil, let sit for 5 to 10 minutes.
Perfection.
I used to do both salt and pepper however I don't serve them with a sauce instead have some black slat flakes in a grinder. I find its too salty if I do both. Each to their own though.Why only pepper? As I mentioned above salting steaks (at least 45mins before, preferably longer) has given the biggest improvement to them of anything I’ve tried.
Also, err grapeseed oil?![]()
Had mine 3 + years now and love it. Use it 2 or three times a week. Super easy and very low maintenance. I scrape the grill before each use and change the foil on the drip tray and give it a vacuum with an ash vac every couple of months and its hassle free.I'm rewarding myself with a Traeger (or similar, might go for a mavity charcoal system) once I've finished some big garden landscaping work, I can't wait!
Totally do what works for you but honestly pre-salting steaks makes such a huge difference. There’s a Serious Eats article all about it. They come out 10x more juicy, and because you’re essentially brining the steak the seasoning really penetrates all of it rather than just having a well seasoned crust. It’s really worth itEach to their own though.
I just Googled it. Ok, I thought it was a typo on rapeseed oilYeah, grapeseed oil.
