- 7 Jul 2009
- Newcastle/Aberdeen
Took me a while to realize what you meant, but it would be incredibly complex. There were studies into the viability of launching a craft in the payload bay capable of travelling to the moon and back, but doing it with the actual shuttle seems a bit pointless. So much dead weight means so much extra fuel. In fact, lets do some calculations.
Delta V LEO to LLO: ~4000m/s
Shuttle capacity: ~24,400kg
Orbiter mass (not 100% but): ~78,000kg
Say you used the main engines, which have an exhaust velocity (in vacuum) of about 4,440 m/s.
Given that Δv = Ve * ln[R], and R = M / Me:
R = 102400/78000 = 1.3128205
Δv = 4440*ln(1.3128205 = 1208.5m/s
1208.5m/s < 4000m/s
So my conclusion is no, it would not be possible. And that's without even considering the mass of the extra equipment, storage tanks, heat shielding etc.
I also read an article about moving the ISS to Lunar orbit, can't seem to find it but using traditional engines you would need a massive amount of fuel due to the immense mass of the station. Using ion engines i believe you could get close in terms of required delta-v, but the thrust would be so low that it would take years, by which time the resistive forces due to the particles that do exist up there would just keep adding to the requirements. Also by which point, i might add, you could probably have constructed a whole new station over there using traditional methods.
If you want to learn more about the calculations:
http://www.projectrho.com/rocket/
1208.5m/s < 4000m/s
