Did the pencil mod on my Asus P5KC last night as i think i was suffering quite bad vdroop. Before the mod I was experimenting with the vcore set in BIOS at 1.45, this showed in cpu-z as 1.40 at idle and then 1.320 under load (so quite a big drop)
After having done the mod i am now getting 1.440 in cpu-z at idle and also under load (it doesnt change). I hope this is a good thing, but should it actually go down a bit under load for safety reasons or is it ok running the same at idle or under load???
