Hey all, i've been thinking of finishing off my eclipse asap as i've recently upgraded and have it sitting here at a silly angle with the side off while i work out what to do
I only have 2 x hdd and 1 x dvd-rw in there, for now, and was trying to think of the best way to do things, i'm planning on a 120mm Noctua 1200rpm fan for the front (The older one i have in there isn't pushing nearly enough air) and i was wondering if mounting the hdd's in the floppy bay would be ok? I know they won't have a fan blowing over them but i was thinking either that, the http://www.overclockers.co.uk/showproduct.php?prodid=CA-061-CM&groupid=701&catid=7&subcat=29 coolermaster 4in3 perhaps? Or am open to any other suggestions as what might be best, i would just like to get that bottom HDD cage out to let the Noctua at the front push a bit lot of uninterrupted air straight through, over the 8800 and eventually up & out
Also i wasn't sure how good the Akasa 120mm side panel was? With summer approaching i thought i'd get my cooling updated & sorted now so i'm not sitting next to a living toaster for the next few months!
If anyone has any opinions on what would be a good call to do, i would really appreciate it, thanks!
Also, i will be throwing a Noctua NH-U12F on the 6300 for cool & quiet
Thanks again all
Thanks again all
