I think I am going to put the loop in, without the GPU's...
Given that both AMD and Nvidia are launching in a couple of months, it may mean that I switch out my cards, so I will likely sell them on.
Given this, is it worth buying a new case and beginning the build from scratch, then, when I'm ready swapping the mobo, PSU, etc over to that case?
If the answer is yes, what case would you guys recommend?
Cheers
Ben
Cheers
Ben
