We would continue in a straight line, or as close to it [due to other gravity sources], in the direction we were going when the effects of gravity ceased.
Out of curiosity, what would happen then?
Well the entirety of modern physics is built upon that assumption (and by extension, all other sciences too), so…
So if what u say is right, black holes shouldn't be black...
They appear black as no light reaches us from them. They could be electric pink for all we know.
They are black because light cannot escape them
How comes the light from stars orbiting the centre of a galaxy (a black hole) can reach us?
How? Gravity is a force and hence is acceleration whereas the speed of light is a velocity. How can the two be the same?
1: The behaviour would depend on the material interface between the two boxes. If we take an idealised scenario with a perfectly isotropic surface (i.e. it "looks the same in every direction"; no alignment of microscopic surface irregularities etc), then the top box will be stationary, since the box below it is exerting a periodic force which have a net force of zero over the period of oscillation. Since the bottom box is moving so rapidly it's reasonable to assume that the force will be plenty enough to overcome the static friction, so the top box would not "move with" the bottom box. There would, however, be a whole assload of friction created, which would heat up the surfaces of the two boxes very quickly.
But surely once the lower box has moved out from beneath the upper box's centre of mass, the upper box will begin to tip to one side? This may be a very small effect for one oscillation, but since the lower box is oscillating so rapidly, it'll very quickly accumulate.
First of all in order to offer a precise answer these cubes need a mass. Galileo. Secondly on the properties of the speed of light, is relative to the observer and as such we the observer would not see 3 different cubes we would in fact observe a contracted cube, it’s length would be squeezed depending on the direction it was travelling. Einstein.
Galileo again and a little bit of Newton. Given the gravitational pull of the earth on the upper cube. The upper cube would need mass in order to fall otherwise it will remain stationary. However given a mass the cube will fall in accordance with the related theory.
Newton’s law of universal gravitation. Forces will be exerted by and upon the falling object and the lower moving object. Gravitational radiation (wave displacements) will theoretically extend along the ‘x’ axis in both directions (left and right) from the lower cube and along the ‘y’ axis from the upper cube(although possibly much smaller displacements).
Come on you people this is a simple clear case of classical mechanics. As observers it would appear to the eye that there is no movement. That the upper cube is not displaced. However it can be measured that the upper cube does in fact wobble however the displacement would be in the sub microscopic realm. Of course this is merely theory since the gravitational effect of the earth exerts a stronger force than these theoretical cubes. However it does not follow that this may be the case at all since we have no value of mass for either cube and that the results could be much different in a vacuum with inertial frame of reference.
Needs more name-dropping.
Photons are massless![]()
All forces are transmitted by massless particles which travel at the speed of light (at least according to our current best theories of physics). Electromagnetic forces are transmitted by photons (which we can detect with relative ease), whereas gravitational forces are transmitted by gravitons (which we cannot yet detect reliably).
No. Think of it more as gravity effecting space itself that the photons have to travel in. As a 3D example, stretch out a large sheet of elastic material. Place a large weight in the centre, creating a dip (this is our gravity well). If you were to shoot a lot of tiny balls across this sheet, as the balls come within decreasing radii of the weight they be increasingly effected, initially as a change in direction (gravitational lensing) but within a certain radius they will not be able to escape (they have crossed our even horizon).ThePirateHulk said:Surely they can't be as if they were they would be unaffected by gravity. Doesn't an object have to have mass for it to be affected by gravity?
