this is for my golf. i put new suspension on lastnight (only had time for the front). the car is about 10mm higher at the front than it was yesterday
this morning i started to hear a grind/gumble
the noise wasnt apparently immediately, it took a couple miles to become audiable and its nasty gridning noise
it is not apparent on throttle (any load, light or heavy) but you hear it as soon as youre off the throttle or coasting
it is the same whether clutch is up or down (so sort of ruling out gear box) but NOT the diff
the sound "feels" like its coming from my feet area.
so place your bets
1) inner CV (would that be noisy off load, silent on?)
2) diff (i have a feeling it could be diff) but its not a whine, its a grind
what do you recon?
so place your bets
what do you recon?
