- 25 Nov 2005
Is your name Ernie ?Other half bert stared me for replying to a thread about tin cans.
No, they are plastic lined. Its a very thin lining but its there.
Tin cans refers to steel lined food cans generally.
Coatings
There’s always a thin plastic layer (coating) inside drink cans to protect the food or liquid and to protect the cans from corrosion. Every soda contains phosphoric and citric acid and it’s thus necessary to add a hidden liner inside the can to prevent the beverage from reacting with the metal.
Coatings contain different additives, e.g. agents to increase surface slipping as well as abrasion and scratch resistance of can coatings, lubricants, anti-foaming agents, adhesives, scavengers for hydrochloric acids, and pigments.
Are Cans More Sustainable than Plastic Bottles?
A short overview of Aluminium and Steel cans.bioplasticsnews.com
I read the magnetic bit as 'they are magic'Metal Recycling| Think Cans
Metal recycling explained. How to tell the difference between aluminium and steel: the most commonly used forms of metal packaging.thinkcans.net
Disagrees with you.
I feel like a vegan living in Cornwall mortgage free right now.You've definitely had too much sun!
Disagrees with you.
Maybe a tin plated steel can is preferable to a bpa lined alu can?
Which bit disagrees, I am struggling to see what part is the issue?
"Steel cans are made from tin-coated steel (which is why they are often called ‘tin cans’)."
24 cans of tango dark berry 9KG
24 cans of Pepsi cherry 8.3KG
both packed the same packing in those plastic wrap with weak cardboard to hold them up
Tango and Pepsi are from the same parent company so packing very unlikely to be much different
All liquid is the same weight so how is there almost a kg difference ?
Basically undrinkable tbha bit less precise with the measurements on the Tango packaging or are sticking 9kg on all of the boxes whether diet versions or not.
Oil is lighter than water. Water is surprisingly heavy but ice is least dense hence it floatsCorrect me if I’m wrong but all liquid weights the same if both liquids are the same ml?
Used to be tinned cans, because thats process, but later shortened to tin cans or just tinsTin. Hence tin cans or tinnies.
