- 29 Jan 2010
ive looked around quality and feature wise d5300 seems best for £500 is this true?
anything better
anything better
I'll keep an eye out and see if i can get it at the right price. ThanksI'd start with the D7100 instead.
Edit:- Might be of interest; https://photographylife.com/nikon-d7100-vs-d7000
I have one, brilliant camera. Have you thought about lenses? I suspect if you buy used it might come with a kit lens, but if you ever find yourself buying just a body, consider the 35mm f1.8 DX prime lens for your first purchase (it's a 50mm equivalent if you're talking 35mm), cracking lens and super sharp for less than 150 quid new.I'll keep an eye out and see if i can get it at the right price. Thanks
Also, don’t forget the 7 series have the LCD on top for viewing settings quickly. I used to think this wasn’t that important, but I find it invaluable now on my 7200 and will never buy another DSLR without one.
One thing to note is that if you wanted to have a go at Sports or fast action photography, then the 7200 is a far better option as it has a much larger continuous shooting RAW buffer. The 7100 takes around 3 images before the buffer fills. It then goes to 1 image a second. The 7200 will rattle off around 18 14-bit RAW images in a row, more if you choose the 1.3x crop option. Much better for action photography.
Is MBP a good place to pick up a camera (£404 -449)? Are there any alternative places?
Not at lossless 14 bit shooting. Trust me, I’ve got a D7200. It’s around 18 raw images.It's not quite that bad. The buffer of the D7000 holds 12 raw images and the D7100 8, D7200 is 26.
Ebay.
Ok, so when I’m shooting in continuous, why do I only get 18 images before buffer fills?Nah, I'll take the manufacturers specification list and the independent verifications of those specifications over your word.
Oh, and check this for 14 bit lossless shooting https://cdn-4.nikon-cdn.com/e/Q5NM9...A8w==/PDF/D7200-D7100_Comparison_Sheet_en.pdf
It’s not that, you will see from the link that even Nikon state 18 images for 14-bit lossless RAW.I would imagine you have a card that doesn't support the write speeds needed?
While more would be nice, its a bit out of my price range. Also you can kind of "compensate" by getting a UHS class 3 card.Ok, so when I’m shooting in continuous, why do I only get 18 images before buffer fills?
...or waiting for a D5300 to go on sale and picking that up?
Thanks for posting but i've just bought D7100.I happened to notice that Amazon have the D5600 kit for sale at the moment, thought you might be interested. Quite a few Nikon bits and pieces appear to be on sale actually, I'd have a root about.
Excellent choice! Have you got a lens for it? Or did it come with one?Thanks for posting but i've just bought D7100.
