Question on 3930k
26 Aug 2012
North West
Bought a Cooler for my 3930k, but it was damaged so it needs to be returned. Would it be fine running my CPU on the stock heat sink, or would I need to use Cooler. It won't be Overclocked just running on stock speeds.
Oh no it won't.
The 3930K does not come with a heatsink.
i thought that too, so i would be very wary of what cooler/heatsink you put on, unless you know for sure it is designed to fit the cpu.
I got a retail version that came with a small heatsink (apparently).
http://www.overclockers.co.uk/showproduct.php?prodid=CP-392-IN&groupid=701&catid=6&subcat=1672
The Orignal CPU Cooler I got had a bolt that was badlly threaded, so when I screwed it in, the springs shot back into my face... So it is going back and I have ordered a new one.
But...
Overclockers UK said:
- Core Size: 32nm
- Socket: LGA2011
- Six Core
- Frequency: 3.20GHz (3.80GHz TURBO)
- Multiplier: 32x (Upto 40x available)
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- TDP: 130W
- DOES NOT INCLUDE COOLER
- 3yr Warranty
No the 39X chips do not come with a cooler
None of my 3930's or 3820's did.
It is a very small box, no cooler inside.
from product description
Core Size: 32nm
- Socket: LGA2011
- Six Core
- L3 Cache: 12MB
- TDP: 130W
- 3yr Warranty
You really need a decent cooler with the 3930K
I recommend the D14 lga 2011 special
I did buy one but the threading on one of the screws was gone so had to send it back and order a new cooler. New cooler won't be here till tomorrow, when you just spend £2000 on a rig waiting is a hard lol.
