- 18 May 2010
- London
Do all the i7 9xx range clock the same? (Theoretically)
ie. is it worth buying say a i7 950 over the i7 920, as the 950 starts at 3ghz... and hence will theoretically overclock higher than the 920?
Would the 950 require less volts than the 920 at the same overclcok frequency?
Are there any difference in overclocking potential between the i7 range?
