I'm fairly sure Pagefile.sys is the swap file
I've disabled the swap file on the C drive (and enabled it on another drive)
I still have a pagefile.sys in the root of my c drive, I wouldn't mind so much but it's 3Gb, is it safe to delete?
Also looking for it it seems to be locked as it doesn't let me remove the attributes for system hidden or archive from a command prompt
What application can I use to remove these attributes
Thanks in advance for any help
Wyv
EDIT:
If it makes any difference I'm running XP 64
Wyv
EDIT:
