Question what if time does not exist?
Wouldn’t it be great if the entire world should understand that what we call ‘time’ actually is our own process of change? A huge cosmic process happening in the eternal now!
Wouldn’t this awaken us and make us realize that all together and inspired by the eternal now, we can take the next step in our spiritual evolution?
This really would make a difference. People should strive to adapt to life as it should be, which means taking responsibility for the earth and its inhabitants.
Who or what is to say what life is as it should be? an awakening to the bigger picture may make some realise the small mindedness of the ego but there is no logic which dictates what life should be unless you inject an unsubstantiated religious theme (as the author does).
That website's has at the bottom "The mission of Science and Nonduality (SAND) is to forge a new paradigm in spirituality, one that is not dictated by religious dogma, but that is rather based on timeless wisdom traditions of the world, informed by cutting-edge science, and grounded in direct experience."
Sounds like a cult to me........................ :p
If you're lost you can look and you will find me
Time after time
If you fall, I will catch you, I'll be waiting
Time after time
If you're lost, you can look and you will find me
Time after time
If you fall, I will catch you, I will be waiting
Time after time
We already knew that reality is an illusion and reality exists in space-time so it's no surprise that time is an illusion. Space must be an illusion too since it's so intrinsically linked.
I've watched Doctor Strange so you could call me a bit of an expert in the subject I guess.
I've always found it suspicious that time seems to fit into sections way too easily. For example 60 seconds in a minute then 60 minutes in an hour. That's way too much of a coincidence.
Time... in my opinion is just a what we use to track the movement and passing of.... Time.
I use the word Time in the latter part of that sentence, because what word can I use to describe it?
