- 13 Aug 2011
I recently purchased a Radeon HD6450 which cost a mere £40. I need some answers about graphics cards in general as I really am struggling to understand the differences:
1) I played Half Life 2 with all settings on high using this graphics card. I found the graphics don't seem very sharp. Is this because the graphics card is quite cheap or is this because the game itself is fairly old?
2) What exactly should I be looking for when upgrading the graphics card? My graphics card is relatively new and I see there are other graphics cards that are much much more expensive. What is the difference between a cheap one and a more expensive one? If I buy a more expensive one then will games like Half Life 2 look much better even if the settings are on the highest like when using mine? Or will it make no difference because the game is fairly old?
Many thanks any graphics cards you would recommend?
