Hi, have probably "stupid" questions about partitions:
1) does partitions influence performance (friend of mine told that if you make partition (example 500gb hdd - partition 1 250gb, partition 2 250gb) hdd gon' work slower) ???
2) someone istalls programs/games to second partition???? (NOT A "C" driver where is windows) so if you want to change windows in future, your installed games won't be deleted, so you don't have to bother installing again???
if "YES" - yet again, will performance of the game will be as fast as if you install on driver "C" ?
thanks
thanks
