Questions and loop expansion.....
8 Oct 2013
ok i had better explain. I started off with a d5 xspc bay res pump combo and a 360 rad to cool my cpu. Then got a block for my 290 and another 120 rad.
But i want to add another 290 to the loop and well here is where i get awkward.
I know nothing at all about pumps! the vibration from this bay res pump combo has driven me insane so i was wondering if i can take this d5 and just use a different pump top or something (you screw the casing onto the res at the moment i think)
Oh also my poor case has been cut to bits to fit rads so far so because i always was a sucker for bbb cases i just ordered a 900d to fit everything in it (and have enough space to fit a small dog spare)
Soooo looking if i can change res options and keep pump? also how much would you add on rad wise? keep in mind i don't lack the space and well if your going to do something you may as well go over the top :D
So i am looking best case scenario for:
new res
new pump mounting top something or other
more rads
going to go with gentle typhoon fans
Also a good way to control a hell of a lot of fans since my manual fan controller is a pain and my motherboard refuses to allow me to adjust fan speeds (flaw on motherboard version)
