What do you think of the config below?
I'd like to have a quiet PC for Multimedia and office use (web surfing + videos + Excel & Word, etc), usually have a lot of applications running together but no video or images editing or gaming
Specific question on the motherboard: could I get a cheaper one? same thing for the cpu cooler?
would like to have an usb 3.0 port?
Many thanks
CAS: CoolerMaster Silencio RC-551 Mid-Tower Silent Gaming Case Black featured front USB 3, Internal sound damping. [+2]
CD: 24X Double Layer Dual Format DVD±R/±RW + CD-R/RW DRIVE. (BLACK Colour)
CPU: Intel® Core™ i3-2120 Dual Core 3.30 GHz 3M Cache LGA1155 + HD Graphics [-53]
FAN: Coolermaster Hyper 412S CPU Fan with 4 x Direct Contact heat-pipes, Extreme performance and Ultra quiet ***Overclockable XXX*** [-2]
HDD: 1TB SATA-III 6.0Gb/s 7200RPM Hard Drive (Single Hard Drive) (Single Hard Drive)
HDD2: 128 GB Crucial M4 Series SATA III Gaming MLC Solid State Disk [+89] (Single Hard Drive)
MEMORY: 8GB (2x4GB) PC10666 DDR3/1333mhz Dual Channel Memory [+24] (Corsair XMS3 w/Heat Spreader [+20])
MOTHERBOARD: Asus P8Z68-V LX Intel Z68 Chipset DDR3 ATX Mainboard w/ 4 RAM slots, BT GO! LucidLogix Virtu and Intel SRT, 7.1 HD Audio, GbLAN, USB3.0, 2x SATA-III RAID, 3 PCIe Gen2, 2 PCIe X1 & 2 PCI ***Overclockable XXX*** [+24]
NETWORK: ONBOARD 10/100/1000 GIGABIT LAN PORT -- As standard on all PCs
POWERSUPPLY: 500 Watts Power Supplies (CyberPower 500W Gaming Power Supply (No Overclocking recommended))
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
USB1: Built-in USB 2.0 Ports
USB2: USB 3 Hubs -- Tsunami SS U34 (4x USB 3.0 Ports) [+19]
XWNA: Asus USB-N13 802.11b/g/n USB 2.0 300Mbps Wireless USB Adapter [+17]
Many thanks
