- 18 Mar 2003
A few questions if I may.
Looking at purchasing an M.2 / PCIe 250GB SSD to be used for database work (large files, 300MB-1GB in size). Rig will be
* New i5-6600K
* Z170
* 950 or 951
* HD5670 (it's not for gaming)
* Win 8.1 32bit and / or CentOS (64bit) or equivalent (Fedora)
M.2 or Adaptor?
It seems a PCIe adapator is faster than the M.2 port and yet some mobos state this:
1x Turbo M.2 32 Gb/s
Does that mean you can get the full 2000MB/s Read, 900MB/s Write from the M.2 port directly, and that there is no need for the adaptor card to get the fastest speed?
and then there is this beast:
"Twin Turbo M.2 64Gb/s + Turbo U.2 ready"
What is U.2? Are there drives that work with it now? How does twin turbo work? Does it require two drives?
If the M.2 is always slower than PCIe regardless of the above then is the ASUS and the Lycom identical in performance but one is cheaper?
Overprovisioning
Is that still required for these drives? Of the 256Gb only around 50Gb is actually used so plenty spare.
O/S
I understand the 950 is retail and thus has drivers to allow booting in Windows. Are there also drivers for Linux or would the 951 be more suitable?
Can these drives be set to dual boot?
Would it be easier all round to just use an 840 Evo as a boot device and run the 950 as the data drive?
* New i5-6600K
* Z170
* 950 or 951
M.2 or Adaptor?
Overprovisioning
O/S
