Quick 8800GTX Question
That's a very good score. You running XP or Vista?
Most I've managed to squeeze so far is appx. 14,600 from a similar spec.
Cheers mate, im running XP at the mo, I should state that ive got my Q6600 benching at just under 3.8ghz
Hoping to get the GTX under water soon so i can see how far it will go :p
Winngames, How much difference does your PhysX card make?
not much if any :( i havnt really had a chance to experience its full potential seeing that theres only about 2 games out that actually use it. ive played the demo of graw2 and even with my spec its unplayable on high, i dont know if its a pc problem, a driver problem or a physics card problem.
i would recommend waiting until more games that support it come out, ive only got one because it came free with my dell 720
I've seen that on loads of reviews. I think it's because it causes so many more objects to be rendered by the gfx card.
That's was what I was thinking.
It may not even take off as loads of games are using physics engines that make use of multiple core CPU's now.
