Evening all.
Have been thinking about upgrading to an SSD in the near future and have heard that when installing you must set your BIOS to AHCI.
Before I buy I just thought I'd try this with my system as it is - it's currently set to 'Enhanced IDE', and my motherboard is an 'Asus P7P55D'.
Problem is, when I set it to AHCI the system will post and try to load Win7-64, but then just restarts when you would usually see the desktop.
Is this a problem that should stop me buying an SSD? Is this just because the OS was installed under IDE (not a prob if buying SSD as will fresh install)..?
Ideas welcome
Ideas welcome
