- 1 Jun 2014
Howdy! I'm looking for a single 120mm AIO cooler recommendation.
It will be cooling a 6700K. I'll be overcolcking as much as the cooler allows, but top priorities are quiet performance and reliable build quality. I can replace the stock fan with a Gentle Typhoon if needs be, so really just looking for something with a good, quiet pump. No RGB bling or extras needed either. Also, I'm not in the UK, so you can recommend stuff not carried by OcUK if you think they're worth looking at.
Thanks in advance!
Thanks in advance!
