Hi,
I have a few questions regarding SATA vs. IDE, and thought I would ask here as I can't seem to find a definitive answer via searching (unless I'm missing something). Can't make up my mind really about it all.
I am looking to get a new HDD, as the one I currently have I want to use in a set-up in my arcade machine at some point. I currently use a 120GB Seagate Barracuda IDE model plugged into an Abit AV8 with an Opteron 146 running Win98SE (yeah I know i'm a bit behind on the operating system but it's done me fine for years until now, it's just starting to look like needing to be reinstalled!
I was looking at getting another 120GB, possibly 160GB IDE but then I saw the SATA (I presume they are all SATA II drives now) drives and thought I might be better off with one of those. Thing is, are they as easy to install Windows on as IDE? I mean just plug in and go - i'll be putting on Windows XP now. I know I can make it NTFS and all that, but will I really see a speed difference? I play the odd game (very) occasionally, but I do use it to watch avi files and more than anything else I use a lot of emulators on it. I presume by what I read that these SATA II drives are backwards compatible with SATA I so I can use it on my current set-up and also keep it if I upgrade the boards, etc?
Many thanks
).I was looking at getting another 120GB, possibly 160GB IDE but then I saw the SATA (I presume they are all SATA II drives now) drives and thought I might be better off with one of those. Thing is, are they as easy to install Windows on as IDE? I mean just plug in and go - i'll be putting on Windows XP now. I know I can make it NTFS and all that, but will I really see a speed difference? I play the odd game (very) occasionally, but I do use it to watch avi files and more than anything else I use a lot of emulators on it. I presume by what I read that these SATA II drives are backwards compatible with SATA I so I can use it on my current set-up and also keep it if I upgrade the boards, etc?
Many thanks
? Also, it says to boot from the "Onchip SATA raid", by this I assume it means it can handle both a SATA set-up and a RAID array?
