Quick case help!
29 Oct 2002
Per title, mate has just bought a 280MM AIO, problem is his case is cack (Corsair 600T?) and doesn't support a large radiator, so we need a quick bit of help!
Case needs 3+ front USB if possible, with at least a single external 5.25" drive, window is optional but it must be able to support the 280MM rad, any suggestions please?
I'd offered https://www.overclockers.co.uk/cors...dition-mid-tower-pc-case-black-ca-196-cs.html which he might have to settle for (only 2 USB on the front) but does anyone have a better option?
Cheers as always!
DB
Edit: Nevermind, impulsive plum ordered the Carbide 275R ><
