Quick component check
10 Apr 2004
Are these things any good?
Abit out of the loop now I've stopped custom building and gone fully Apple :o *shock horror*
ASUS Maximus Formula SE motherboard- X38 chipset
Intel Quad Core Q8300 -> Q6600 better?
*Removed*
eVGA GeForce 9800 GT 512 -> A Hmmm from me.
My brother is trying to compile a computer upgrade, say a spec for CPU, Mobo, Mem and GPU for £300?
PSU is a 4 year old OCZ 580W which should be enough to take on what he can afford tbh.
Ideas?
STORM SILENT 900W PSU -> Never heard of them myself!
Ideas?
What parts do you have know??
Also avoid the STORM SILENT 900W PSU!!
This is what I would look at getting:
AMD Phenom II X3 720 ~ £100
http://www.overclockers.co.uk/showproduct.php?prodid=cp-238-am
asus m4a77d ~ £60
http://www.overclockers.co.uk/showproduct.php?prodid=mb-376-as&groupid=701&catid=5&subcat=1482
has all solid capacitors and supports 140w phenom ii processors too
4gb 1066mhz ddr2 ~ £71
http://www.overclockers.co.uk/showproduct.php?prodid=my-192-cs&groupid=701&catid=8&subcat=817
hd4770 512mb ~ £74
http://www.overclockers.co.uk/showproduct.php?prodid=gx-117-pc&groupid=701&catid=56&subcat=
the total comes to around £305 excluding postage.
the x3 720 is similar to a £133 q8400 in games:
http://www.anandtech.com/bench/default.aspx?p=83&p2=89
the x3 720 compared to a core i3 530:
http://en.inpai.com.cn/doc/enshowcont.asp?id=7488
http://www.anandtech.com/bench/default.aspx?p=118&p2=83
there is not much difference between using ddr2 and ddr3 with the current phenom ii processors:
http://www.tweaktown.com/articles/1782/amd_phenom_ii_ddr2_vs_ddr3_performance/index.html
http://www.tomshardware.com/reviews/phenom-x4-955,2278-3.html
The HD4770 is faster than an 9800GT:
http://www.pcper.com/article.php?aid=700&type=expert&pid=4
Many of the cheaper 9800GT cards are downclocked versions which are bus powered.
Also socket 939 X2 processors usually reach a good price on a certain well known auction site.
Yeh i'd replace that storm psu. I had the exact same one in my previously pre built q9550 system untill i started replacing stuff and fiddling with it.
This is what I would get:
Phenom II X4 955BE ~ £122
http://www.overclockers.co.uk/showproduct.php?prodid=cp-244-am
asus m4a77d ~ £60
the total comes to around £253 excluding postage.
the phenom ii with 1066mhz ddr2 has around the same performance with ddr3:
asus m4a77d ~ £60
Thanks, need a GPU in there too tho.
So it seems AMD is the performance for price king at the moment!
Cheers
I got a nice cheap Gerforce 9600 GSO which does the job on games playing them near max + phyx is quite nice, if not that for the ati 4850.
Cheers
Phenom II X2 550BE ~ £72
http://www.overclockers.co.uk/showproduct.php?prodid=cp-249-am
asus m4a77d ~ £60
hd4670 512mb gddr3 ~ £56
http://www.overclockers.co.uk/showproduct.php?prodid=gx-184-sp
the total comes to around £259 excluding postage.
Since the Phenom II X2 550BE is based on the Phenom II X4 quad core over 70% of them in this thread have been unlocked to triple and quad cores:
http://www.xtremesystems.org/forums/showthread.php?t=227004
This is not guaranteed though!
CAT's listing includes all the items you requested and it's always luck of the draw with the 550BE so would be a bonus on top as well. :)
