Hi all,
Just a quick question about Core Voltage.........
Been playing with over clocking my q6600 on a Asus P5KC mobo and at the mo got it running at 3.2 ok.
I have been doing a bit of reading and googling etc but am unsure when i am read people core voltage which figures i should be looking at.
In my bios i have had to set it to 1.5375v to run at 3.2ghz (9*356) but when on CPU-Z when idle the Core Voltage reads 1.480 ish and when under load (using Prime95) 1.376 ish.
Temps have been 37 idle and max of 65 under load (this is core#0 others been a few deg lower?)
I want to try to get to 3.6 ghz if poss but will need to increase core voltage to do so (i'm guessing) and have seen that i should be going above 1.55 but is when under load as shown in CPU-Z or my bios setting??
The ram im running is 4gb (4x1) Geil Black dragon pc2-6400 800mhz at 4 4 4 12 on 2.0volt and my gfx card is a Gigabyte 8800GT all in a Antec 900 case with a Freezer pro 7 on W7 64 bit.
Thanks in advance
Mark
Thanks in advance
Mark
