- 22 Mar 2009
- Cornwall
hi, had a phone call yesturday from a mate, his i7 build has been unstable since he bought it, not sure on the spec so will post it once i have the pc but just wanted to see if anyone had any ideas.
basically he built the rig for flight sim X, he has been getting BSOD since the day he had it.
all i know is its an i7 with 12GB ram (6x2GB) and 4 hard drives. pretty sure his gfx is a 480 but will confirm later. i know last time i looked at it his gfx was dead, which we hoped had been the issue from the beginning.
i have run memtest on it which errors on every stick when all are fitted, but every stick passes after a 12hour run if fitted individually.
the bsod codes he had last time are : 0x0000001A, 0x00000027, 0x0000000A, 0x0000003B. he said he has more now so will report them once i see him. i am hoping that its something simple like upping some voltages or something.
he said that it will work for 10-20mins and then BSOD, after restart it then works fine until he next restarts and then the cycle begins again.
sorry for the longwinded post, hopefully will have more details later.
cheers in advance.
cheers in advance.
why do they put 6 ram slots on the mobo if it wont take 6 sticks without a lot of messing about?
