Quick Java Help?
8 Oct 2005
Midlands, UK
Hi,
Am going through a few java tutorials and am coming into problems. I have two text files:
results2.txt in the format "Name Mark1 Mark 2" and results3.txt - here i need to read the stuff from results1.txt and input a third test result and calculate the average. So results3.txt will look like:
"Name Test1 Test2 Test3 Average"
However, I keep getting an input mismatch exception where i prompt the user to enter the test 3 result. Here my code (i'll split it into methods later on):
Code:
public class TestResults2 {
    public static void main(String[] args) {
        Scanner input = null; //Output from results2.txt
        PrintWriter pw = null; //pw for results3.txt
        String name; //Holds name as string
        int testOne=0, testTwo=0, testThree=0; //Holds test scores as int
        try {
            //Open both files
            input = new Scanner(new File("results2.txt"));
            pw = new PrintWriter(new FileWriter("results3.txt",true));
            //Loop through results2.txt, read in marks
            while (input.hasNext()){
                name = input.next();
                testOne = input.nextInt();
                testTwo = input.nextInt();
                //Input markthree from kybd
                System.out.println("Enter 3rd Result: ");
                testThree = input.nextInt();
                //Write all to results3.txt
                int average=((testOne + testTwo + testThree)/3); //Average of 3 scores
                pw.printf("%-15s %5d %3d %5d %5d %n",name,testOne,testTwo,testThree,average);
            }//End While
        }//End Try
        catch (IOException ioe) {
            System.out.println("Error handling file!");
            System.out.println(ioe.toString());
        }//End catch
    }//End Main
}//End Class
i dont really get what your trying to do here. your reading from results2.txt that has 4 strings a line right? and you've made a reference to this file with input but then you have a bit where you get the input for the third test by doing this:
wouldnt testThree in your case hold the average?
I probs explained it crap :)
Results2.txt had a string and 2 ints E.g.
NAME T1 T2
Bill 20 20
I then wanted the user to inout a third int (T3) and to output all scores plus an average of those scores to a txt file called results3.txt - String, int, int, int, int. So the final file may look like this:
NAME T1 T2 T3 AV
Bill 20 20 20 20
Jim 20 20 20 20
etc.
Actually, can't work out why the following prints a blank line at the top of the text file and then the results, gah its so annoying:
Code:
pw.printf("%-15s %5d %3d %3d %3d %n",name,testOne,testTwo,testThree,average);
im assuming it's because you're using input.hasnext as an iterator? and the %n formatter is invoking a new line. It's probably due to your code layout for the printwriter.
Ah cheers. It was becuase i had the pw set to append 9, when its not needed (must write a new line by default). The below works:
pw = new PrintWriter(new FileWriter("results3.txt"));
Cheers for help people.
