6 Apr 2020 at 19:56 #1 wedrum wedrum Permabanned Joined 11 Aug 2016 Posts 5,553 Location Cheshire building a little decking area and using pallets to put a hot tub in a and a gezeebo. pallets are 1200 x 800 decking 2.4m x 120mm hottub is 180cm x 180cm square one. TIA
6 Apr 2020 at 20:06 #3 wedrum wedrum Permabanned OP Joined 11 Aug 2016 Posts 5,553 Location Cheshire m@rty said: 24 Click to expand... how many pallets
6 Apr 2020 at 20:07 #4 whitecrook whitecrook Soldato Joined 22 Aug 2005 Posts 9,024 Location Clydebank wedrum said: building a little decking area and using pallets to put a hot tub in a and a gezeebo. pallets are 1200 x 800 decking 2.4m x 120mm hottub is 180cm x 180cm square one. TIA Click to expand... 42 16 forty-eleven Thats’s numberwang
6 Apr 2020 at 20:13 #5 Yaayuh! Yaayuh! Soldato Joined 5 Nov 2010 Posts 24,748 Location Hertfordshire Twelfty!
6 Apr 2020 at 20:13 #6 adolf hamster adolf hamster Soldato Joined 18 Oct 2012 Posts 8,367 Your out of luck i'm afraid, those are completely different numbers
6 Apr 2020 at 20:16 #7 Destination Destination Soldato Joined 31 May 2009 Posts 21,503 Have you tried turning it off and then on again?
6 Apr 2020 at 20:16 #8 wedrum wedrum Permabanned OP Joined 11 Aug 2016 Posts 5,553 Location Cheshire adolf hamster said: Your out of luck i'm afraid, those are completely different numbers Click to expand... i have built one before a few years ago but cant remember how many pallets i bought.
6 Apr 2020 at 20:20 #9 sigma sigma Caporegime Joined 13 Nov 2006 Posts 29,780 Just buy one large pallet to cover the whole area.
6 Apr 2020 at 20:21 #10 wez130 wez130 Soldato Joined 31 Jan 2004 Posts 11,325 Location Matakana New Zealand Is that a Bugatti Veyron?
6 Apr 2020 at 20:28 #11 kaiowas kaiowas Soldato Joined 18 Oct 2002 Posts 10,785 Location Castle Anthrax That is a *very* little decking area.
6 Apr 2020 at 21:49 #12 Danm54 Danm54 Associate Joined 20 May 2009 Posts 1,857 kaiowas said: That is a *very* little decking area. Click to expand... Even in cm it's still too small for the hot tub...
6 Apr 2020 at 21:51 #13 wedrum wedrum Permabanned OP Joined 11 Aug 2016 Posts 5,553 Location Cheshire Hot tub is 1.8m decking is 2.4
6 Apr 2020 at 21:58 #14 andy_mk3 andy_mk3 Soldato Joined 5 Oct 2009 Posts 14,552 Location Spalding, Lincs This problem is beyond the power of math.
7 Apr 2020 at 07:25 #16 Danm54 Danm54 Associate Joined 20 May 2009 Posts 1,857 wedrum said: Hot tub is 1.8m decking is 2.4 Click to expand... But the decking is 1.2m wide, the hot tub is 1.8m
7 Apr 2020 at 07:42 #17 Efour Efour Caporegime Joined 8 Sep 2005 Posts 30,631 Location Norrbotten, Sweden. Yep just hang 60cm into the bushes. No problems
7 Apr 2020 at 08:18 #18 ElliorR ElliorR Soldato Joined 20 Feb 2009 Posts 10,410 Location Not where I'd like to be 5
7 Apr 2020 at 15:18 #19 Angilion Angilion Man of Honour Joined 5 Dec 2003 Posts 21,063 Location Just to the left of my PC My question is...what is the question? Danm54 said: But the decking is 1.2m wide, the hot tub is 1.8m Click to expand... According to the OP, the decking is 2.4m long and 120mm (0.12m) wide. A plank. Going to be quite the balancing act in that hot tub Not sure why they mixed m, cm and mm with such gay abandon though. Or why they didn't ask a question.
7 Apr 2020 at 15:22 #20 Mason- Mason- Soldato Joined 18 Jun 2010 Posts 6,893 Location Essex Put everything in the same units, ffs. Use mm or cm for everything. Are you saying it's a 2400mm square decking that is 120mm high?
