Decided to mod my case... something along the lines of this:
http://forums.overclockers.co.uk/showthread.php?t=17604376
I was thinking of adding mesh to replace the see through perspex on the side panel to improve airflow. Airflow in my case is shocking with the water pump blocking the inlet.
I was thinking this would improve airflow especially if I put a fan on the side as well. Also with my side panel off, CPU temps drop as much as 10c!
Anyone know where to look for this type of mesh? I’ve looked in a few DIY shops with no luck.
Thanks
Thanks
