Quick Nvidia Control Panel G-Sync Question
Caporegime
8 Jul 2003
In a house
Just got my new rig, with the 2070 Super, and noticed in the Nvidia control Panel, Set Up G-Sync, it had ticked, Enable G-Sync, G-Sync compatible, and Enable for Full Screen mode, selected under 1. Apply The Following Changes , so i switched that to Windowed and Full screen mode.
Now, do i also have to tick, under 3. Display Specific Settings (my monitor is displayed under 2 correctly, its the BenQ EX3501R, which is seemingly G-Sync compatible), Enable Settings For The Selected Display Model, too.
As ive been seeming to be stuck in 60hz, even though when i set the resolution and Hz setting, in the Nvidia Control Panel, to their correct settings, 3440x1440p 100Hz.
Noticed by my mouse not being silky smooth, and stuttering, but now ive ticked under 3. Enable Settings For The Selected Display Model too, it has now gone to 100Hz, as mouse, dragging windows about etc... gone silky smooth, no stuttering.
Thanks.
Don't have a clue about Nvidia now, as ive not been on them since the 8800s, its all changed :p
EDIT: although thinking about it, that might not have anything to do with the Hz. :p
When i look under Windows Settings, Advanced Display Settings (im now on 10 :eek:), its got my Hz as 99.
Weird.
OMG, you actually have an Nvidia card finally. Welcome to the dark side. Lol.
Now you can begin enjoying your new card by slating it non-stop on here. You can start with the RT performance :cool::p:D
Yep :D
Well i turned her on today, and shes 100hz fine, so i don't know what was happening yesterday, as everytime id restarted, or switched off/on, it would revert to 60hz, even though it was saying i was on 100hz, and if i went and just fiddled with the hz, swapping between them all, and Applying, it would eventually kick the 100 in, well odd. :p
Yep :D
Glad you got it working. Now install that huge catalogue of RT games report back on how it goes :p
