25 Apr 2008 at 21:21 #22 Ferro Ferro Associate OP Joined 22 Apr 2008 Posts 17 how does that differ from your original spec? Theyre about the same cost if you remove the drive from spec 1.
25 Apr 2008 at 21:30 #23 Glaucus Glaucus Man of Honour Joined 11 Mar 2004 Posts 76,678 Ferro said: how does that differ from your original spec? Theyre about the same cost if you remove the drive from spec 1. Click to expand... better ram and better gfx card
25 Apr 2008 at 21:31 #24 triggerthat triggerthat Soldato Joined 26 Aug 2005 Posts 6,901 Location London Corsair 2GB DDR2 Value Select PC2-5300C5 Dual Channel Kit (2x1GB) (VS2GBKIT667D2) £23.99 (£28.19) £23.99 (£28.19) OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £59.99 (£70.49) £59.99 (£70.49) Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) - Retail £38.99 (£45.81) £38.99 (£45.81) Gigabyte GA-P31-DS3L Intel P31 (Socket 775) PCI-Express DDR2 Motherboard £39.99 (£46.99) £39.99 (£46.99) Sub Total : £162.96 Shipping cost assumes delivery to UK Mainland with: City Link Parcel Next Day (Delivered Mon-Fri) (This can be changed during checkout) Shipping : £8.25 VAT is being charged at 17.5% VAT : £29.96 Total : £201.17
