Quick Photoshop help needed!
26 Jun 2005
I'm making a collage of some pictures I took. I'd like the background to be black to make the pictures stand out more. So far I've set up all the pictures in the right places and each one is on an individual layer so I can remove them at will.
How do I get the background to be black though?
Cheers.
If not, make a new layer by clicking the new layer button at the bottom of the layers panel and fill it black. You may need to drag it to the very bottom depending on which layer you have selected when you create the new one.
Ok, another bit of help needed please.
I've compiled the collage of about 12 JPEG's, each was on a separate layer. I've saved this large Photoshop file and also Flattened the layers and saved that too as a *.PSD file.
I want to get the file printed out but Photobox can't see the .PSD file and Photoshop won't give me the option to save it as a JPEG? Its a large file, about 35Mb. Any ideas?
Goto, File, Save for Web and save it as a PNG, GIF or JPEG or similar :)
JPEG should be an option in the drop down box on the save as screen
Another shortcut for you.
If you have a layer selected and the colour that you want (in this case, black) just hold ALT and press Backspace. That will automatically fill it in :)
If the primary colour is white and the secondary colour is black, switch them with X. And to get back to default black/white just press D (I think, not got photoshop at work)
