It isn't really about gearing, unless you're cycling out of the normal range. An off-the-shelf bike will have an adequate range of gears for normal use.
Not at that price range they wont. Most will be under geared for road use.
You're right and I am out of date. When I last looked, most people who were looking for a bike to be used on the road were sold a bike designed to be used on the road. I'd wrongly assumed that was still true.Not at that price range they wont. Most will be under geared for road use.
You got an XC bike, then used it for DH ??? Sounds nuts imohave no bike at the moment. Used to have A kona lava Dome heavily modded for Xc and some down hilling. Until it got stolen and then I never replaced it (no insurance)
why would you want hydrolic brakes on what is essentially a road bike. It's utterly pointless. You won't stop any quicker.
isnt the most important thing that he likes the feel of his new bike ? and even if is lil harder than a racing bike just means getting better work out from riding to and from work
Strictly speaking I don't. I just want breaks that can stop me on a six pence if need be as when on the road I seem to be surrounded by idiot pedestrians and motorists.
I am sure modern U breaks on Road Bikes are very good, especially if you can afford Ultegra or Record.![]()
Riding on a MTB is like driving in your car with the hand brake slightly depressed. Yes you'll still get there, but the engine is working harder.
Riding a tourer, flat bar racer or road bike will mean he'll go faster, with less effort, keeping speed up (less road friction and wind resistanec) and enjoy the ride better. I hated riding to work on my MTB - it took twice as long, I arrived knackered. On the roadie I actually enjoyed it, and overtook a couple of cars on the dual carriageway
Until your ride a roadie you think a MTB is nippy, it isn't. It's a canal barge. Regardless whether you're unfit or fit.
) I see about four or five riders on MTB's and one on a road bike (old steel framed job)The limiting factor is the tyres. As long as the breaks lock the wheel up. It doesn't matter what brakes you have you wont stop quicker. All you get is more feel and heat absorbing. This is not needed on a road bike.
If you're doing 35mph you need a fair bit of stopping distance...you'll never do this speed on a MTB on the flat.
I max out at 22mph on the flat on my MTB. It sucks as it is too slow and is a hell of a lot of effort!
