I'm after a new eSata to eSata cable to connect my Icybox to my pc as the one that came with it is very short. I want one 2m or longer but i don't want to compromise the integrity of data transferred or lose any speed.
I was looking for something on ebay:
3m eSATA to eSATA High Speed Cable 3 Gb Lead External
The info listed is:
They are £5.75 delivered. Would one of these be OK?
The info listed is:
PRODUCT INFROMATION
3 METRE STRAIGHT ESATA TO ESATA DATA CABLE
3GB/S
EXTERNAL USE
Connects an external eSATA device to a eSATA controller with this high speed cable, Metal latches on the connectors ensure secure contact to both PC and device.
FEATURES:
Supports SATA data transfer speeds of up to 3Gbps (ie Sata II).
ESATA 7 pin male to ESATA 7 pin male.
7 wire data cable which is very durable and flexible.
External SATA Data Cable
Data transfer speeds in excess of 300Mb/sec
ALL CABLES AND ADAPTERS ARE FULLY ROHS COMPLIANT ENSURING THE HIGHEST OF STANDARDS IN THE EU.
