afternoon all, just a quick question regarding hot swapping drives.
I just got one of these http://www.overclockers.co.uk/showproduct.php?prodid=HD-031-BT&groupid=701&catid=14&subcat=72 and installed it, its working fine but i've just noticed that my hard drives aren't listed in the safely remove hardware thingy, they defiantly used to be there but I can't when they stopped being there as I only just noticed. How do I go about safely hot swapping the drive? I've never done it before and always assumed that you would use the safely remove hardware jobby and then just swap the drive. My motherboard is an Asus A8N-E.
Thanks in advance
Geuben
Thanks in advance
Geuben
