- 3 Jan 2006
Hello,
I need a new case to fit my new motheboard (Gigabyte p35-DS3P) bought from Cob on the MM.
I was looking around the £40 but this is negotiable if the more expensive boards provide more bang for buck. I'm a medium level gamer and just need something quiet, cool and has space for air flow. I'm planning on fitting an Arctic Cooling Freezer Pro 7: http://www.overclockers.co.uk/showproduct.php?prodid=HS-017-AR
So here are the contenders:
Akasa AK ZEN 01 £35.24 http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-AK
Gigabyte GZ-X2 £34.09
http://www.overclockers.co.uk/showproduct.php?prodid=CA-014-GI&groupid=701&catid=7&subcat=
XClio 6030 PLUS Black £34.24
http://www.overclockers.co.uk/showproduct.php?prodid=CA-023-OK&groupid=701&catid=7&subcat=
I know that there are others such as the Coolermaster Centurion (£46.99) But I don't know if the extra money would be worth it.
Advice much appreciated thank you
Joe
Joe
I always choose the case (or any other stuffs) based on its potential, not just how its at stock
If you want a cramped/dusty/a cable management nightmare case you have made the right choice...
