either use the stuff that is pre-applied to the cooler.
Or, wipe it off, then apply a pea sized blob to the top of the cpu, then you can either fit the heatsink and give it a little wiggle to spread the stuff, or spread the pea sized blob yourself with a finger in the corner of a food bag.
