Gays the pair of you.
ok Thanks
My friend told me to make sure 'Econ' was off? - So what does it do with 'Econ' off?
Also - There are two temps on the display - What is each one for?
Hi
To turn off the Air Con - you just make sure 'econ' is off right?
Thanks
God know it makes almost 0 mpg difference!
Why turn it off at all?
The temp on the left is the outside temperature.
The temp on the right is the temperature you have set with the blue and red buttons.
On my old one (a 115), switching on the ac added .5 second to the 0-60
Did you actively accurately measure your 0-60 from a similer start with your aircon on and off in a 115hp passat?![]()
Yep, six runs on an open road with ac on, 3 in each direction and the average taken.
