I currently have a 7700X under a DeepCool AK620 in my Fractal Torrent Compact. I have the two stock intake fans on the case, 3x120 intake at the bottom (although they're linked to GPU temp) and the two stock fans on the cooler. No active exhaust, although with front the intakes running there's a strong flow of warm air out the back.
The CPU manages to boost as it should, but only just. The CPU hist 95C instantly under load and sits there permanently. I know that's just how these chips operate, but if the cooling was genuinely keeping up then I would expect either slightly higher boost clocks, lower temps or fans not at 100%, right?
I've cleaned everything, tried re-seating the cooler and tried a few different thermal pastes from quality brands. No improvement.
I'm now looking at an upgrade to a 9850X3D, which has roughly the same power draw as a 7700X. Should I upgrade my cooling or is there just something wrong with my current setup? I'm not keen on an AIO so it would be something like an NH-D15 or Peerless Assassin 140, assuming that would actually be enough.
