quick question regarding audio inputs..
18 Jun 2011
hello all,
i frequently change from my main speakers ( logitech z5500 )
to my headset ( razer banshee )
now i usually go to
control panel > audio > etc, and then select which source i want.
my question is this,
is there a simpler way to do this, be it assign the change to a button to flick from one to the other or even just assign the output to a button for each one ?
thanks in advance, James
You could right-click on the speaker icon on the system tray, Playback Devices should take you directly where you need to be.
