quick question, X99 to X299, operating system re-install?
26 Jan 2010
I have updated my Asus Strix X99 motherboard to a X299 Asus Strix motherboard
Also CPU updated to a i9
Everything else the same, same operating system install, upon starting the PC the COMPUTER states new CPU detected
Did a update or some sort of repair, anyway the old Windows 10 from the X99 build booted up perfectly
Now am I to do a new windows install?
Will I face issues if I keep this old but convenient operating system on my new PC?
Will still work okay and should not encounter any issues really.
Personally though, when moving platform I usually take the opportunity to freshly install windows again.
Windows 10 is pretty good at handling this sort of thing. Any version of Windows prior to that really required a clean install.
No point reinstalling until there is a problem.
I've had the same Win10 install for a while, started out life on a X99/5960X, then to a Ryzen 2700X, then a 8086K, now on a 9900K. Runs just fine, all I did was run driver cleaner and reinstall chipset and GPU drivers after each swap.
The install even started off on a different SSD - started out on a 512GB 950Pro, then I shrank the C: to 250GB and cloned it on to it's current 970EVO.
Windows 10 is really difficult to break.
I'd recommend a clean install for sure, I went from one laptop to another and it was a headache trying to keep Windows without reinstalling, in the end clean install and was very snappy.
