Quick raid0 question
gorebrush is right here but I should also mention that you will need to 'build' the array which deletes what is already on the drives and then format them, can I ask why you want a Raid0 setup? From your question I'd surmise(maybe wrongly) that you don't know too much about it at the moment so you might be setting one up when you won't get much benefit.
Yes, just as an example.
I use RAID-0 on a pair of 36Gb Western Digital Raptors, connected to an Adaptec SA1210 SATA PCI Card. When this card is added, it adds a new screen to the POST process of the PC before Windows starts loading.
From there I am offered "Press CTRL-A to enter Adaptec Setup"
(or something similar)
From there I have to go in and build an array as semi pro waster rightly points out. This is so the card knows how to handle both disks, and effectively control them "as one" at a hardware level. When I then run Windows Setup, it then sees this as One Logical Disk, as opposed to two Physical ones.
Do you need to know more about how RAID-0 functions?
SameSuspect said:
To setup raid0, do both of the drives have to be new and unused?
No.
If you put different drives into an array though, it will be limited by the slower drive of the 2.
Using two different drives will probably negate any positive effects of having a RAID0 Array. In other words dont bother unless the disks are the same.
SiriusB
