Quick spec check
4 Sep 2003
Cornwall
Hi all,
Just putting together a new mid-range system for my brother. I'm a bit rusty so would appreciate if someone could cast an eye over this and see if I've made any glaring errors. This is pretty much max budget.
YOUR BASKET
1 x HIS HD 7850 IceQ X 2048MB GDDR5 PCI-Express Graphics Card (H785QN2G2M) £155.99
1 x Intel Core i5-3470 3.20GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £149.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x Zalman ZM 500W GT '80 Plus Bronze' Power Supply £52.99
1 x Kingston HyperX Beast 8GB (2x4GB) PC3-12800C9 1600MHz Dual Channel Kit (KHX16C9T3K2/8X) £44.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD £43.99
1 x BitFenix Merc Beta Gaming Case - Black £29.99
1 x Asus 24x DVD±RW DRW-24B5ST SATA ReWriter - Black (OEM) £21.98
Total : £579.91 (includes shipping : FREE).
Cheers!
I'd change that PSU for XFX, Seasonic, Antec, Corsair or BeQuiet! There is no point rushing in to a purchase because other items are out of stock, especially the PSU. If it's not a well built PSU, you'll take all the components with you if it goes BANG!
Otherwise, looks great!
Try and get a bit more and you could get something like this:
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £43.99
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £39.95
1 x **B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £33.5
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
Total : £585.38 (includes shipping : FREE).
- Cheaper but same optical drive.
- i5 3570k over the i5 3470.
- Better case.
- Better PSU.
- Cheaper, low profile RAM which performs the same.
YOUR BASKET
- Better case.
- Better PSU.
Ah, nicely done. hadn't thought to look in B grade. Is that RAM considered OK?
TeamGroup is a good make. It's low profile aswell, compared to the Kingston, which means that in the future it'll be easier to install heatsinks if you want to do so.
