Quick Thunderbird question
Faz
Faz
18 Oct 2002
Just put the latest version on my laptop but cant find the option to display my inbox when it opens. It works fine on my desktop and pc at work but I can't find an option to enable it any ideas
Cheers faz
I think you will find that if you uncheck the box in Options/Thunderbird start page, it will auto start with your Inbox. I installed v2 over the previous one, so it kept everything as it was anyway.
Yup. Tools>Options>General tab. Thunderbird Start Page. Uncheck the box and next time Thunderbird should go into the Inbox. Just done that myself and I quite like it. Saves me two mouseclicks getting from the main page to my Inbox.
Thanks. :D
Thanks for the replies, tried that but it doesn't work, might try a re install of thunderbird
Faz
Faz
I don't understand why that dose'nt work Faz. I have just done it on my other 2 rigs and laptop, it works the same with all of them :confused:
Me too, it works on my desktop and works pc but not on the laptop. I'm reinstalling thunderbird now
